X
Sections
Get StartedContribute
How to Develop Using Vagrant
Edit this Page
If you have a more advanced project and use Vagrant to run your development environment in a Virtual Machine, you'll often want to also run webpack in the VM.
Configuring the Project
To start, make sure that the Vagrantfile has a static IP;
Vagrant.configure("2") do |config|
  config.vm.network :private_network, ip: "10.10.10.61"
end
Next, install webpack and webpack-dev-server in your project;
npm install webpack webpack-dev-server --save-dev
Make sure to have a webpack.config.js file. If you haven't already, use this as a minimal example to get started:
module.exports = {
  context: __dirname,
  entry: "./app.js"
And create a index.html file. The script tag should point to your bundle. If output.filename is not specified in the config, this will be bundle.js.
<!DOCTYPE html>
<html>
  <head>
    <script src="/bundle.js" charset="utf-8"></script>
  </head>
  <body>
    <h2>Heey!</h2>
  </body>
</html>
Note that you also need to create an app.js file.
Running the Server
Now, let's run the server:
webpack-dev-server --host 0.0.0.0 --public 10.10.10.61:8080 --watch-poll
By default the server will only be accessible from localhost. We'll be accessing it from our host PC, so we need to change --host to allow this.
webpack-dev-server will include a script in your bundle that connects to a WebSocket to reload when a change in any of your files occurs. The --public flag makes sure the script knows where to look for the WebSocket. The server will use port 8080 by default, so we should also specify that here.
--watch-poll makes sure that webpack can detect changes in your files. By default webpack listens to events triggered by the filesystem, but VirtualBox has many problems with this.
The server should be accessible on http://10.10.10.61:8080 now. If you make a change in app.js, it should live reload.
Advanced Usage with nginx
To mimick a more production-like environment, it is also possible to proxy the webpack-dev-server with nginx.
In your nginx config file, add the following:
server {
  location / {
    proxy_pass http://127.0.0.1:8080;
    proxy_http_version 1.1;
    proxy_set_header Upgrade $http_upgrade;
    proxy_set_header Connection "upgrade";
    error_page 502 @start-webpack-dev-server;
  location @start-webpack-dev-server {
    default_type text/plain;
    return 502 "Please start the webpack-dev-server first.";
The proxy_set_header lines are important, because they allow the WebSockets to work correctly.
The command to start webpack-dev-server can then be changed to this:
webpack-dev-server --public 10.10.10.61 --watch-poll
This makes the server only accessible on 127.0.0.1, which is fine, because nginx takes care of making it available on your host PC.
Conclusion
We made the Vagrant box accessible from a static IP, and then made webpack-dev-server publicly accessible so it is reachable from a browser. We then tackled a common problem that VirtualBox doesn't send out filesystem events, causing the server to not reload on file changes.
Contributors:
Contributor to this page
