X
Sections
Get StartedContribute
How to Configure Hot Module Replacement?
Edit this Page
Hot Module Replacement (HMR) exchanges, adds, or removes modules while an application is running without a page reload. HMR is particularly useful in applications using a single state tree, since components are "dumb" and will reflect the latest application state, even after their source is changed and they are replaced.
Webpack's power lies in its customizablity, and there are MANY ways of configuring HMR given the needs of a particular project. The approach described below uses Babel and React, but these tools are not necessary for HMR to work. If you'd like to see examples of other approaches, please request them or, better yet, open up a PR with an addition
This guide will be demonstrating the use of HMR with Babel, React, and PostCSS (using CSS Modules). To follow along, please add the following deps to your package.json:
To use HMR, you'll need the following dependencies:
npm install --save-dev babel@6.5.2 babel-core@6.13.2 babel-loader@6.2.4 babel-preset-es2015@6.13.2 babel-preset-react@6.11.1 babel-preset-stage-2@6.13.0 css-loader@0.23.1 postcss-loader@0.9.1 react-hot-loader@3.0.0-beta.1 style-loader@0.13.1 webpack@2.1.0-beta.20 webpack-dev-server@2.1.0-beta.0
In addition, for the purposes of this walkthrough, you'll need:
npm install --save react@15.3.0 react-dom@15.3.0
Babel Config
Your .babelrc file should look like the following:
  "presets": [
    ["es2015", {"modules": false}],
    //Webpack understands the native import syntax, and uses it for tree shaking
    "stage-2",
    //Specifies what level of language features to activate.
    //State 2 is "draft", 4 is finished, 0 is strawman.
    //See https://tc39.github.io/process-document/
    "react"
    //Transpile React components to JS
  "plugins": [
    "react-hot-loader/babel"
    //Enables React code to work with HMR.
Webpack config
While there's many ways of setting up your Webpack config - via API, via multiple or single config files, etc - here is the basic information you should have available.
const { resolve } = require('path');
const webpack = require('webpack');
module.exports = env => {
  return {
    entry: [
      'react-hot-loader/patch',
      //activate HMR for React
      'webpack-dev-server/client?http://localhost:8080',
      //bundle the client for webpack dev server
      //and connect to the provided endpoint
      'webpack/hot/only-dev-server',
      //bundle the client for hot reloading
      //only- means to only hot reload for successful updates
      './index.js'
      //the entry point of our app
    output: {
      filename: 'bundle.js',
      //the output bundle
      path: resolve(__dirname, 'dist'),
      publicPath: '/'
      //necessary for HMR to know where to load the hot update chunks
    context: resolve(__dirname, 'src'),
    devtool: 'inline-source-map',
    devServer: {
      hot: true,
      //activate hot reloading
      contentBase: '/dist',
      //match the output path
      publicPath: '/'
      //match the output publicPath
    module: {
      loaders: [
        { test: /\.js$/,
          loaders: [
            'babel',
          exclude: /node_modules/
          test: /\.css$/,
          loaders: [
            'style',
            'css-loader?modules',
            'postcss-loader',
    plugins: [
      new webpack.HotModuleReplacementPlugin(),
      //activates HMR
      new webpack.NamedModulesPlugin(),
      //prints more readable module names in the browser console on HMR updates
There's a lot going on above, and not all of it is related to HMR. You may benefit from reading the full documentation on webpack dev server, and the other articles here on webpack.js.org.
The basic assumption here is that your JS entry is located at ./src/index.js, and that you're using CSS Modules for your styling.
Please see the comments inline that explain each portion of the config. The main areas to look are the devServer key and the entry key. The HotModuleReplacementPlugin is also necessary to include in the plugins array.
There are two modules included here for the purposes of this guide. The react-hot-loader addition to the entry, as noted above, is necessary to enable HMR with React components. The NamedModulesPlugin is a useful addition to better understand what modules are being updated when using HMR.
Code
In this guide, we're using the following files:
// ./src/index.js
import React from 'react';
import ReactDOM from 'react-dom';
import { AppContainer } from 'react-hot-loader';
import App from './components/App';
const render = () => {
  ReactDOM.render(
    <AppContainer>
      <App/>
    </AppContainer>,
    document.getElementById('root')
render();
// Hot Module Replacement API
if (module.hot) {
  module.hot.accept('./components/App', render);
// ./src/components/App.js
import styles from './App.css';
const App = () => (
  <div className={styles.app}>
    <h2>Hello, </h2>
  </div>
export default App;
// ./src/components/App.css
.app {
    text-size-adjust: none;
    font-family: helvetica, arial, sans-serif;
    line-height: 200%;
    padding: 6px 20px 30px;
Now, the above code is using React, but it doesn't need to be. In fact, the only thing that matters above is the code refering to module. First, we wrap the HMR code inside of module.hot check; webpack exposes module to the code, and if we are running with hot: true configured, we'll enter the inside of the conditional.
While the module API offers more options than what's above, the most important element is the module.hot.accept call. It specific how to handle changes to specific dependencies.
So in this case, module.hot will fire the render method ONLY when src/components/App.js changes. Note that would also include when the dependencies of App.js change - so the render method will file not just for changes made directly to the source of App.js, but also changes made to App.css, since App.css is included in App.js.
Package.json
Finally, we need to start up webpack dev server to bundle our code and see HMR in action. We can use the following package.json entry:
  "scripts": {
    "start" : "webpack-dev-server --env.dev",
Run npm start, open up your browser to localhost:8080, and you should see the folling entries printed in your console.log:
dev-server.js:49[HMR] Waiting for update signal from WDS…
only-dev-server.js:74[HMR] Waiting for update signal from WDS…
client?c7c8:24 [WDS] Hot Module Replacement enabled.
Go ahead and edit and save your App.js file. You should see something like the following in your console.log:
[WDS] App updated. Recompiling…
client?c7c8:91 [WDS] App hot update…
dev-server.js:45 [HMR] Checking for updates on the server…
log-apply-result.js:20 [HMR] Updated modules:
log-apply-result.js:22 [HMR]  - ./components/App.js
dev-server.js:27 [HMR] App is up to date.
Note that HMR specifies the paths of the updated modules. That's because we're using the NamedModules plugin.
Contributors:
Contributor to this page
